I thought I'd seen it all.... That has to be a manufacturing fault. No "normal" cause of failure would have done that. I've seen it countless times....... And worse. Ditto. A friend had a 400 of unknown origin that he wanted to throw a cam in. It was running but weak when we pulled it apart. The cam bearings looked even worse!
'63 Dodge 330 11.19 @ 121 mph Pump gas, n/a, through the mufflers on street tires with 3.54's. 3,600 lbs. 10.01 @ 133mph with a 250 shot of nitrous an a splash of race gas. 1.36 60 ft. 3,700 lbs.
