we had a hardware coming loose problem a few years back. turned out to be harmonics as our balancer/damper was going south. we changed it & after that our problem was gone. are you using the same damper as before as you might want to look at this. i know its hard to believe something like this can happen but i've just changed the replacement damper as we were seeing things fail again.
