I can solve that valve cover gasket issue for you Brad but it will cost a bunch of money! Once I made billet valve covers for my stuff the leaks went away. Your issue would be even harder to solve since custom valve covers would also require custom gaskets. Might be easier to have a good shop add a bead of weld on the valve cover rail so the gasket if fully supported on the intake side.
