ok, I found the extensive part of the oil leak. Was leaking from the valley pan directly under the intake. Pulled the cover, cleaned it up good and sealed it with the Right Stuff. Installed the cork valve cover gaskets, went for a power ride and no leaks. non, not even a drop. Cool, I'm sure happy with that cause this thing was leaving pools of oil on the cover.
