I myself who too has experienced leaks of uncertain origin have learned points from this thread which may prove of value in the determination of the cause of my own valve cover sealing issue.
If Dave had merely called your firm instead of using this forum for advice, which all agree is a valuable tool, I and others would not have benefited from the shared wisdom of fellow members.
Would you not all agree that this would be a a primary purpose for the existence of this forum?
