Are you running a roller cam.. if so the intermediate shaft could be worn a fair amount which causes slop and timing issues
Hey thanks everybody for the ideas , I was thinking about the bronze gear also . It may be worn a little because I do run a roller cam and it has been in there for quite a while.
