Pretty well ALL of the consoles in B and C bodies of each year are the same...
Since you capitalized ALL, a couple exceptions are: 70 Fury same as B; 70 Chrysler is different, 65 Chrysler has different top plates from B and Fury, 65 Monaco 500 extends 2-3" into the rear bench seat (which is unique), 66 Charger is full-length, 1-year-only.
Probably a few other years I overlooked.
C body consoles had a rear chrome plate that had a cigar lighter mounted in it, and the horizontal vanes were opened up so you can have elegant floor lighting in the rear of your b body console, Just switch the plate out and run some wiring.
