So instead of screwing around with that scirocco radiatior i went ahead and ordered a lightweight 26"x19" two row dual pass griffin with AN inlet and outlet. For pump i got a allstar 20-25gpm pump and i am going to use -12an lines.
I am going to pull that shogun manifold and drill out the restrictor in it. Should have good enough restriction with the dual pass radiator.. I will just have to come up with a good fan setup for it. Will probably hit up junk yard and find something.
