never been a fan of the bouchillon set up.. too cluttered and ugly looking
I had one installed for about a month on the B-van, Flimsey setup and adjusting it was a exercise in frustration. Of course the masterpiece of their 'kit' is the Chrysler designed cable from the early 90's 'RH' transmissions with their stuff at either end, they leave that part out. I found an OEM 4BBL linkage from another B van and promptly installed it, adjusted once and it worked perfectly.
