The 2 wires coming out of the distributor end in a connector. The 2 wires coming from the orange box to the distributor end in a connector. These 2 connectors are shaped in a way that they can only be out together 1 way. I didn't look at those wires closely because they were set up to obviously plug together with those connectors. I'll look them.
With the rest of the orange box wires I put black to negative terminal on coil, and blue to to blue ignition 1, and didn't use green wire because there was no pin for it and the kit also came with a 2 terminal ballast resistor
