Ok I finally got to mess with it again... I had a old rod that someone welded up. But it was 2 inches to long I cut it. Re welded it Made huge differance. If I can take the slack out of the rod to pedal il be good.. So i have a question. Can I adjust the lower rod pushing the throw out bearing against the pressure plate fingers/arms to take the slack out of the top rod or should the bearing not touch while pedal at rest?
1970 barracuda convert. 1 of 59 1970 pro street A.A.R. clone (panther pink) 1971 charger 2015 hellcat challenger. Redline red 2014 quad cab 4x4 ram 8 speed hemi
