....and I should have read the WHOLE thread. This bracket I did will have you in the same position you are presently in. I'd have to look at my 47re case and see if something like Jake mentioned would work. You're swimming in uncharted waters I'm thinking. Time to get creative! I do know that part of the case is pretty sensitive. Many a trans has been cracked there from simply over tightening line fittings.
