Had to drill open the holes where the shield meets the trans bellhousing and bolts to the block. The shield sat up a bit too high on the trans placing the holes too high to get the bolts in straight to the engine block. Also the things mentioned above with the drivers side bell crank boss needing to be cut off, and the strap bracket.
