Poorboy, thanks for the info. The car is a 1941 Chrysler Royal business coupe. Its in reasonable shape but everything needs to be restored.
The 1999 Ram truck is mine and I plan to keep it until the 1941 is done.
We do plan to upgrade to front power disc brakes, and rear axle assy.
Plan is to keep it as stock looking from the outside.
Information on modifying the 1999 Ram wire harness would be nice. I suspect I need to use the eng/tran computers as well as fuse box from the Ram. There will likely be many wires not needed.
Mike
