I'd start with Metro/Metro SUPER SOFT gaskets, anything that don't fit or seal properly I'd try Steele products as a substitute for those problem gaskets, no guarantee they will work either, door gaskets/weatherstrips are the biggest hurdle because of profile and/or material durometer being incorrect, most find good originals or NOS are the only course of action with door seal and or roof rail seals, the Metro A pillar wing/vent window gasket is an extremely well fitting piece as are most of the Metro gaskets except the aforementioned problem areas
