Zero issues with factory distributor and vacuum advance
Found this
NOTE: This head will need to be machined for clearance if used with a MSD Ready to Run distributor.
Need a question answered
I noticed the intake manifold bolt threads are open on these heads, drilled through
Should i use a sealant on my ARP Intake Bolts like Hylomar or Anti-Seize or ?
Dont want any oil puddles on valley pan
Also the Edelbrock / Fel Pro Blue Perma Torque Head Gaskets should bee installed dry correct ? And looking at these gaskets it shouldnt matter what side is up or down
Thanx Scott
