Yeah I just looked up the P sheets for PPG's omni brand polyester and they say specifically NOT to use it directly over etching primer. The info for the slick sand doesn't say not to use it, but it doesn't say to use it over etching either so that's indication enough. The sheets for the featherfill G2 say you can use it right over etching but it'll lengthen drying time.
