Started on tightening up the rear bumper, these things from the factory have a filler panel that warps and breaks plus stick out a good 2 inches on either side, the front is far worse.
I used the trim holes to weld temp brackets to 1/4-20 bolts for placement of the bumper, I will make a new mounting setup next with some built in adjustability
Exceptional Architectural, Yacht and Automotive scale models. e-mail modelmakerinc@att.net for a portfolio review. www.modelmakerinc.com
