Here are the mods done to the driver side motor mount as per Schumacher directions, with considerable more mods than they say.
The power steering box is getting swapped for a manual so i had to make the extention. The brake booster is going to be from a 75 Dart which is smaller in diameter to clear the big block valve cover.
The engine compartment is stripped of everything, and k frame will get cleaned up before reinstall. Lots of scraping cleaning then some paint.
Exceptional Architectural, Yacht and Automotive scale models. e-mail modelmakerinc@att.net for a portfolio review. www.modelmakerinc.com
