I purchased the Fel Pro 1213 Intake manifold gasket for my small block which Ive never used before.
Typically I use those fel pros wit hthe blue surfaces. With the blue ones, i dint use any rtv or adhesvise on the intake to head surfaces- just along the front and rear rails and in the corners.
The fel pro 1213 is a fiber like gasket with rubber rings around the intake and water ports. the cross over port is covered.
The instructions say to use a QUICK DRYING adhesive around the ports to hold it on. It says small amount of Silicon can be used around the water ports. Then you bolt down the intake until the glue dries and then remover it and cut the gasket to fit the ports.
So what kind of QUICK DRYING adhesive is recommended?
