ya, im still trying to figure out the best way to block the ports. Im going to pick up a couple of block off plates they use on the Bbig blocks to see if they will work. If not, i may just cut out a section of that gasket an put in some exhaust manifold (metal) gasket material.
I dont like the original idea of stuffing the opening with aluminum foil after looking at how its set up
