Re: '72 'Cuda Build - 5.7L Hemi, 6spd, etc.
[Re: GoodysGotaCuda]
#2261231
02/28/17 07:54 PM
02/28/17 07:54 PM
Posts: 1,822 Colorado
denfireguy
Colorado
Your build is similar to mine but on [/size]Steroids. [size:11pt] I too had my car for a long time (25 years but you are younger than me), ran the socks off of it and then started a rebuild. I did not do a hemi, I wish I had. Put in a used 5.2L married to a lockup A904. The other thing different, I added my toddle after it was done. But all the wiring, upholstery, dash rebuild, engine swap, transmission rebuild, etc. was done in my two car garage in a covenant controlled townhouse. Wish I has seen your body flip trick. I have seen your posts on other boards and I know your electronics aptitude is high. That was my background. Never rebuilt a transmission before but had torn down a lot of engines. I admire your shop and engineering skills. I dumped the Tanks, Inc tank because of leak issues, most of them my fault. Just got tired of draining the tank then dropping it 4 times just to get the leaks to stop. I went with Spectra and have had no leaks and if there is one, remove the left rear tire and there is all the plumbing. I am running Megasquirt 2 and if I ever run a hemi, it will be a Megasquirt 3. The project on my desk now is a PWM closed loop regulator circuit to eliminate my mechanical regulator. I went with Vintage Airs bracket for the 318 and put a Sanden R12 (read early Mustang) scroll compressor on. I had to electronically control the clutch as it was getting so cold, it was freezing up on 90 degree days. All of the plumbing is the stock stuff it came with but I crimped new hoses on the old fittings. I used barrier stuff so if I do have to go to 134, I can. Good luck on the build. BTW, you can get a car seat to work in the back seat. Have to add a bracket to tie the top of the seat strap to the frame. My toddle loves it.
2014 Ram 1500 Laramie, 73 Cuda Previous mopars: 62 Valiant, 65 Fury III, 68 Fury III, 72 Satellite, 74 Satellite, 89 Acclaim, 98 Caravan, 2003 Durango Only previous Non-Mopar: Schwinn Tornado
Entire Thread
GoodysGotaCuda
12/06/16 03:03 AM
GoodysGotaCuda
12/06/16 03:03 AM
GoodysGotaCuda
12/06/16 03:04 AM
GoodysGotaCuda
12/06/16 03:05 AM
JDMopar
12/06/16 03:39 AM
skicker
12/06/16 04:00 AM
GoodysGotaCuda
12/06/16 05:01 AM
GoodysGotaCuda
12/06/16 04:59 AM
UCUDANT
12/06/16 03:25 AM
MuuMuu101
12/06/16 07:07 AM
GoodysGotaCuda
12/06/16 01:21 PM
GoodysGotaCuda
12/06/16 01:27 PM
MuuMuu101
12/08/16 07:29 AM
GoodysGotaCuda
12/06/16 01:43 PM
Keepat
12/06/16 03:38 PM
GoodysGotaCuda
12/07/16 03:17 AM
GoodysGotaCuda
12/08/16 06:14 AM
GoodysGotaCuda
12/18/16 06:21 AM
JDMopar
12/18/16 06:38 PM
GoodysGotaCuda
12/18/16 07:26 PM
JDMopar
12/19/16 02:32 AM
GoodysGotaCuda
12/19/16 03:07 AM
UCUDANT
12/19/16 02:42 PM
GoodysGotaCuda
12/21/16 03:46 AM
MuuMuu101
12/21/16 05:37 AM
GoodysGotaCuda
12/21/16 05:48 AM
GoodysGotaCuda
12/23/16 03:21 AM
JDMopar
12/24/16 09:20 PM
GoodysGotaCuda
12/25/16 06:28 PM
NV69B7RR
12/26/16 07:19 PM
GoodysGotaCuda
12/30/16 12:42 AM
GoodysGotaCuda
01/02/17 04:48 AM
GoodysGotaCuda
01/05/17 01:53 PM
FrankenScamp
01/05/17 02:53 PM
GoodysGotaCuda
01/05/17 03:55 PM
FrankenScamp
01/08/17 08:57 PM
GY3
01/09/17 02:46 AM
GoodysGotaCuda
01/23/17 05:25 AM
Bad340fish
01/23/17 05:43 PM
captainjerky
01/27/17 06:21 PM
GoodysGotaCuda
01/29/17 04:41 PM
GoodysGotaCuda
02/06/17 03:58 AM
JERICOGTX
02/06/17 05:34 PM
GoodysGotaCuda
02/15/17 02:34 AM
denfireguy
02/28/17 11:54 PM
GoodysGotaCuda
03/03/17 03:09 AM
GoodysGotaCuda
03/04/17 05:30 AM
scf100
03/15/17 07:19 PM
GoodysGotaCuda
03/16/17 02:46 AM
GoodysGotaCuda
03/27/17 12:20 AM
CDN72SE
03/28/17 06:43 PM
GoodysGotaCuda
03/29/17 10:09 AM
GoodysGotaCuda
04/02/17 07:54 PM
FrankenScamp
04/03/17 12:40 AM
GoodysGotaCuda
04/03/17 12:24 PM
GoodysGotaCuda
04/03/17 12:25 PM
FrankenScamp
04/28/17 04:39 PM
GoodysGotaCuda
04/29/17 02:18 AM
GoodysGotaCuda
04/29/17 02:20 AM
RylisPro
04/29/17 06:01 AM
GoodysGotaCuda
04/29/17 06:15 AM
gtx6970
06/09/17 10:29 PM
GoodysGotaCuda
05/08/17 04:08 AM
killermopar
05/08/17 03:41 PM
Bad340fish
05/11/17 06:30 PM
GoodysGotaCuda
05/12/17 01:35 AM
Bad340fish
05/13/17 08:48 PM
GoodysGotaCuda
05/23/17 12:52 PM
Bad340fish
05/24/17 04:10 AM
GoodysGotaCuda
05/27/17 12:06 AM
GoodysGotaCuda
06/01/17 04:18 AM
jpilone
06/01/17 09:57 PM
ric3xrt
06/11/17 06:02 PM
GoodysGotaCuda
06/24/17 05:56 AM
FrankenScamp
06/28/17 01:36 AM
GoodysGotaCuda
07/01/17 03:51 AM
UCUDANT
07/03/17 12:35 PM
GoodysGotaCuda
07/10/17 03:21 AM
JDMopar
07/12/17 04:31 AM
GoodysGotaCuda
07/19/17 01:04 AM
UCUDANT
07/19/17 04:01 AM
GoodysGotaCuda
07/25/17 12:59 AM
FrankenScamp
07/25/17 05:11 AM
GoodysGotaCuda
07/25/17 09:41 AM
UCUDANT
07/25/17 01:31 AM
GoodysGotaCuda
07/25/17 04:17 AM
MuuMuu101
07/29/17 02:20 AM
GoodysGotaCuda
09/10/17 08:05 PM
GoodysGotaCuda
09/22/17 03:33 AM
ozymaxwedge
09/22/17 05:27 AM
GoodysGotaCuda
11/20/17 05:57 AM
GoodysGotaCuda
05/28/18 07:36 PM
76Beeper
05/29/18 06:57 PM
GoodysGotaCuda
05/31/18 03:56 AM
GoodysGotaCuda
11/22/18 03:26 AM
GoodysGotaCuda
01/29/19 04:33 AM
GoodysGotaCuda
01/29/19 04:42 AM
tpabayflyer
06/02/19 01:58 PM
GoodysGotaCuda
06/02/19 07:47 PM
modelmakerinc
06/05/19 03:27 PM
GoodysGotaCuda
07/16/19 03:09 AM
gtx6970
07/25/19 07:15 PM
GoodysGotaCuda
08/02/19 02:14 AM
basketcase
08/02/19 02:34 AM
