Originally Posted By 69CHARGERMD
NICE !
Question; What did you use for attaching your breathers on the valve covers ? ( i am doing a 500" INDY motor and need to drill my valve covers and curious what you did with yours,,baffles also ? )
Did you have to use a "smaller" MSD distributor ( same issue,, curious how it clears the INDY covers )
thanks,,,NICE car and motor,
Doug wink
Thanks Doug I appreciate it. The regular MSD Pro Billet distributor works with the Indy valve covers no problem. I use these Mr Gasket grommets with the breathers. Theese grommets do not require any baffles.
68 cuda formula S 588" bb 5sp
70 CUDA CONVERT 500" 5SP (SUBLIME)
70 CUDA CONVERT 500" 5SP (PLUMCRAZY):TOO MUCH HORSEPOWER, IS ALMOST ENOUGH!
