All things being the same if a guy was to install a low gear set in the 727 trans what could he expect to gain ??
How much would it change the 60' or ET ??
Looking to improve my 60' between this and/or a rearend gear change to get it done. I don't have a lot more rpm to use before the stripe, 500 to 700 rpm or so.
What would be some suggestions to accomplish this ??
Already had 2 different conv in it and still was the same.
Its a street/strip car so that is why I thought the trans over the rear gear. I like the idea of the 11.50 class but I need more ET to make it possible.
Thanks Guys, David
