yes some glasspacks alongside the rear leafs will quiet it significantly. I use cheap parts house cherry bombs, the louvers are punched outward and the end nipples do not neck down where they are welded to the main body case, both plusses. It'd very likely be much cheaper than dynomax bullet muffs
