If I recall correctly, there was someone who had worked out a serpentine belt conversion for a B/RB engine without spending stupid amount of money for an aftermarket kit.
The long unsupported run of the twin belts from the A/C compressor on the left to the alternator on the right has me thinking of going down this path. There are no matched pair belts to be found these days and I haven't had any luck finding two belts that will track the same.
We are brothers and sisters doing time on the planet for better or worse. I'll take the better, if you don't mind. - Stu Harmon
