Add up how much money the new pistons, rings, pins, crank work, rod rebuilding and balancing will be including new rod bolts and compare that to the $2200 to get a higher quality stroker kit from 440Source. The difference is the cheapest horsepower per dollar that you can probably find.
Also, get a modern cam grind from a Mopar specialist grinder. The old stuff leaves a lot on the table. Oh, paint those ugly aluminum heads Hemi Orange along with the block.
1970 Plymouth 'Cuda #'s 440-6(block in storage)currently 493" 6 pack, Shaker, 5 speed Passon, 4.10's 1968 Plymouth Barracuda Convertible 408 Magnum EFI with 4 speed automatic overdrive, 3800 stall lock-up converter and 4.30's (closest thing to an automatic 5 speed going)
