OK
I would like to know my options on how to seal the valley area on this Hemi. This is the Indy signle plan, and has NO made in valley cover. I really dont want the Indy plate, if its the same as the Wedge design, how the heads capture the cover. I want to do some track testing against the MP Cross Ram, and want a quick swap. Is welding a plate to the bottom of this intake the only option?
BTW
I got around to fab'n up the linkage for the Cross Ram setup carbs. I was afraid the over the counter linkage kits would not fit right. These are oddball carbs (660 center squirter), and need 1 inch spacers to make the linkage clear etc.. Made the bell crank out of scrap 1/4 motor plate, and the rod tubes out of 3/8 aluminum round stock I drill and tapped for 1/4 rod ends. Very cheap setup, compared to the $300+ linkage kits. See any problem with this setup?
Thanks goes out to a great guy Steve Reasbeck
[color:"red"]65 Hemi Belvedere coming soon [/color]
[color:"#00FF00"]557" Indy engine 1.07 60ft 144mph in the 8th 2100 lbs package [/color]
