Here is what I did , it runs and there is no stumble off of idle , at all , this worked for me.
Drilled out the accelerator nozzles to .045 (went to .041 first)
Installed the .113 primary jets
Installed the .073 X .037 metering rods
Installed the stiffest metering springs
This is close to where I am at so I hope it runs once I finally get going. Can you give a brief description of your motor specs/parts as it would help..
The engine is a 440 , edelbrock intake and 1411 carburetor , cam is suppose to be a mild cam , I bought it this way so I have no idea what it is the engine.
