It would, at least be worth the effort to try them. That much power, with the rpm needed, might be cause for concern with a 1 7/8" tube. The longer the tube, the more the restriction. Works just like resistance in wiring. Smaller tubes, in general, give more torque. Bigger tubes are for mid to high rpm use. You have to watch your fuel curve through mid range with big tubes.
Yes I think it will be worth the effort. I've never built headers before but to make these fit shouldn't be that bad I have a tube chassis car there's lots of room. And my time is free
