Originally Posted By Cab_Burge
You migt want to try using some really thin wire(the thinnest you can get) to make up some upside down J to put in the idle bleeds, all eight thumbs scope That should inrichen the mixture all the way through the entire RPM range scope If that fixes the miss you know your on the edge of a lean misfire at part throttle operations. The next move is to get a set of the next smaller I.D. idle air bleeds, maybe.001 to .003 smaller to fix it thumbs Make sure there are no vacaume leaks also thumbs
Great quick way to test for sure and at least give you a direction to go also the ifr`s and idle bleeds have a big impact. Can you post the specs on the carbs like idles, hi`s, ifr`s, emulsion etc...........
72 Dart 470 n/a BB stroker street car `THUMPER`...Check me out on FB Dominic Thumper for videos and lots of carb pics......760-900-3895.....
