Al,
easiest thing is go up on the primary jets by 2 .Then road test .
Are you running a powervalve on primary ?
Like Cab said vacuum leak at high cruise vacuum - also show as lean
Tex
New best ET 10.259@129.65 .
New best MPH 130.32
Finally fitted a solid cam,
stepped it up a bit more
3690lbs through the mufflers
New World block 3780lbs 10.278@130.80 . Wowser 10.253@130.24 footbraking from 1500rpm
Power by Tex's Automotive
