Thanks, it is also my feeling this has to do with the valve job rather than my fuel pump job. I will contact the guy, seems like it is something that sould be under warranty.
1973 Dodge Charger SE 400 automatic transmission. Curb weight: 3800 lbs. All stock so far. Goal: Reliable everday driveable warmed up 400 as close to 400hp as possible, then a 470 stroker if need be. Don't protect a feminist when the collapse comes!
