Studs also engage all of the threads in the block, whatever the bolt hole depth is, while bolts are restricted to their length minus the cap height.
Make sure you chase the block threads with a bottom tap to be sure you have full threads all the way to the bottom.
2017 Contusion Blue Challenger T/A 392 M6 "BLKNBLU"
