How much horsepower do you think a SB with ARP main studs + H-Beam forged rods could handle ?!
Stock crankshaft and main caps.
I would think in the 800hp range. I run a billet crank
with H-beam rods and I make a little over 700hp
turning it 8200rpm. The build makes a big part in
anything, good light parts and a good balance
EDIT
Thats not on a stock block, I run a R3
