Main Cap Studs..How Much Power? #213249
02/03/09 07:46 PM
02/03/09 07:46 PM
Pa
Hot 340 Offline OP
Hot 340  Offline OP
Pa
How much power do you have to be making to go to a main stud over the regular bolt? Can anyone explain why studding is better?
Re: Main Cap Studs..How Much Power? [Re: Hot 340] #213250
02/03/09 07:57 PM
02/03/09 07:57 PM
IN
ahy Offline
ahy  Offline
IN
The rule of thumb I've heard and used on my engine was around 500 HP. Its very application and tuneup dependant however. If the engine is detonating, it can hurt the bottom end at lower power levels and if everything is just right, higher power might be safe. Better safe than sorry though on the bottom end.
Studs put a higher clamp load on the bearing caps to help them stay put. They change the shape of the cap enough that line honing is needed when switching to studs.
Re: Main Cap Studs..How Much Power? [Re: ahy] #213251
02/03/09 10:35 PM
02/03/09 10:35 PM
Left Coast
BobR Offline
BobR  Offline
Left Coast
I use studs on everything. Real cheap insurance.
Re: Main Cap Studs..How Much Power? [Re: BobR] #213252
02/04/09 10:32 AM
02/04/09 10:32 AM
Ansonia, CT
CJK440 Offline
CJK440  Offline
Ansonia, CT
Studs also engage all of the threads in the block, whatever the bolt hole depth is, while bolts are restricted to their length minus the cap height.
Make sure you chase the block threads with a bottom tap to be sure you have full threads all the way to the bottom.
2017 Contusion Blue Challenger T/A 392 M6 "BLKNBLU"
Re: Main Cap Studs..How Much Power? [Re: Hot 340] #213253
02/04/09 10:43 AM
02/04/09 10:43 AM
MR_P_BODY Offline
MR_P_BODY  Offline
The only thing you get with the studs is a better
clamping force. Also dont bottom the stud in the block
to tighten it down(so it doesnt back out), dont use
locktite to just hold it. What I like to do is drop
a ball bearing down each blind stud hole, double nut
the stud and tighten it in, loading the stud against
the ball bearing. JMO
Re: Main Cap Studs..How Much Power? [Re: MR_P_BODY] #213254
02/04/09 11:32 AM
02/04/09 11:32 AM
Sao Paulo, Brazil
dart_73_br Offline
dart_73_br  Offline
Sao Paulo, Brazil
How much horsepower do you think a SB with ARP main studs + H-Beam forged rods could handle ?!
Stock crankshaft and main caps.
Re: Main Cap Studs..How Much Power? [Re: dart_73_br] #213255
02/04/09 11:41 AM
02/04/09 11:41 AM
MR_P_BODY Offline
MR_P_BODY  Offline
I would think in the 800hp range. I run a billet crank
with H-beam rods and I make a little over 700hp
turning it 8200rpm. The build makes a big part in
anything, good light parts and a good balance
EDIT
Thats not on a stock block, I run a R3
