did I mention it's running pre set the carb, timing ets. fired up on the first hit and idled like it had been running forever. the dominator sounded really crisp. will try and post a video later. wopn't be long now. but I did run into a little snag with my wilwoods. I forgot I have 5/8" rear studs so now I have to find somebody that can drill them out. I have a drill press but don't feel confident I can center them.
On drilling them out to 5/8, use a 1/2" to 5/8" reamer. It is a 4 or 3 fluted tapered self centering drill bit, they work great, u can get them relativly reasonable at fasten all, or sears.
Kasey
Or a Unibit to start drilling the hole then come back with a 5/8 bit to get the rest of the way through...
good ideas guys I'll check into them tomorrow
You sure a 5/8 hole is going to work
no it wont, we have it under control the shank of the stud is .682-.685 in areas so it will take an 11/16 hole.
