Originally Posted By RUNCHARGER
I stepped down from a -10 feed for the carbs to a -8 which splits into -6 to the TB's, I made the return lines all -6. It idles great, is nice and crisp. Reading the literature it suggested running the power through the FITech computer to the in-tank pump. The way I read it the computer will control voltage to the fuel pump to help regulate the pressure.
The Fuel command centre would be nice if you don't want an in-tank pump I suppose, I can't see any reason not to run an in-tank pump though.
Sheldon
Hey looks good !
Not to hijack, but just wondering what your 572 combo specs out like and hows it go in the car with the FiTech ?
wink
smile
