Just Got the FiTech Friday, but I will be using an EFI tank mounted pump.
You can use a surge tank that is filled by the stock low pressure pump, then there is a high pressure EFI pump inside the tank to supply the EFI.
This could even be setup to not use a return line, but the return helps lower the fuel temperature.
