I had a LF caliper that had way too much drag. I replaced it with a parts house $20 rebuilt caliper & it had the normal amt of drag. All good. EDIT If you crack the front caliper bleeders & it frees up then it has to be the calipers themselves as everything upstream is out of the picture
