Can anyone ID this converter, suppose to be a J converter ordered through MP back in 1988 or so. Has no numbers stamped in this except "07". It measures roughly 10 inch. He informed me that is was flashed in the 4K range with very mild big blocks. Im almost 100% sure its not a Turbo Action Unit, they usually are cut out around the backing plate/starter teeth area. It might be a B&M unit?
[color:"red"]65 Hemi Belvedere coming soon [/color]
[color:"#00FF00"]557" Indy engine 1.07 60ft 144mph in the 8th 2100 lbs package [/color]
