Here's some pics.........sorry for the delay. Mine is an old B&M "J". I took a picture of the part number. That number is on it along with a J in front of it. PTC also stamped their numbers in it when I had the snout replaced. Mine is a good footbrake converter with a fairly mild motor in a heavy car, not as good as my newer 8", but still good.
They are very lazy in the 60'.
Yep, They were designed to be a Soft hit vert for more consistant traction. mike
