-HOWEVER, I am only getting from 4-5 volts at the coil. I tried 3 different coils, same story.
What could be causing it not to start? Would it be my ECU? Voltage Regulator? Distributor?
Thanks for any help Paul
With the key in run position, that is the right voltage with the engine not running. In start position with the engine turning over, it should jump to 12V. The voltage should return to 6V with the engine now running. Take a plug wire off and see if you have any spark while the engine is turning over. If you do not, suspect the ECU or the distributor. Craig
2014 Ram 1500 Laramie, 73 Cuda Previous mopars: 62 Valiant, 65 Fury III, 68 Fury III, 72 Satellite, 74 Satellite, 89 Acclaim, 98 Caravan, 2003 Durango Only previous Non-Mopar: Schwinn Tornado
