Originally Posted By MR_P_BODY
I got it all back together today so the leaks should be
all fixed..I'll pull the vent line next time out.. I
should say the rollover valve and the vent line.. and
I'll open the dumps... just curious
wave
Have you run any crankcase pressure checks? Running a PCV system or just venting to atmosphere? ME Wagner makes an adjustable PCV valve ( both for idle and cruise )if you decide to go that route. Could be a leak fixer.
Fastest 300
