before sending them off you might try pre-heating the connecting rod with an electric heat gun (safer than torch's flame) and then packing the inside of the pin with dry ice more and more until is stays solid and if all goes well the pin might then fall out
dry ice is not too expensive usually about $6 per pound and I would guess it will take about half a pound per pin
