Re: checking bellhousing alignment, nessary?
[Re: AlexP]
#207299
01/29/09 01:19 AM
01/29/09 01:19 AM
Posts: 52,972 Romeo MI
MR_P_BODY
This is still the only part of doing my 4-speed swap that I'm not looking forward to.
Its actually quite easy, back when I use to run a stick car I made up a mount that bolted to the flange and held the indacator. It was a 3/8" rod welded to a small plate that bolted to the flange, turned down on the end so I could mount the indacator and adjust it. Once I had the bell housing centered on the crank I tack welded the pins to the block so they wouldnt move. If your smart you do this at the beginning of your engine build up so its just the crank in the block
Entire Thread
dirt
01/29/09 02:43 AM
MR_P_BODY
01/29/09 03:10 AM
Blakcharger440
01/29/09 03:13 AM
MR_P_BODY
01/29/09 03:21 AM
Cab_Burge
01/29/09 04:27 AM
AlexP
01/29/09 05:04 AM
MR_P_BODY
01/29/09 05:19 AM
70Cuda383
01/29/09 05:30 AM
01/29/09 05:32 AM
ThermoQuad
01/29/09 11:04 AM
RTSE4ME
01/30/09 01:26 AM
