Thanks for answers!
I cant use aftermarket K-frame because of class rules where I race. K-frame have to be original. But I really want to use steering rack, much lighter, takes less room etc. BUT problem is Charger`s steering knuckles. They are not front but back of knuckle. So I need to install steering gear behind K-frame. There comes anouther problem - oil pan what is only 1/2" behind K-frame so there is no room. Seems only possebility is to cut and weld oil pan a bit for makeing room for steering rack?
But where you install motor plate? I mean do is stands between block and timing cover and do it fasten to motor same bolts what holds timing cover to motor block?
Georg
you may have a little more luck with a unisteer kit. not sure what year you have but they make a kit for 68-72 b-bodies www.unisteer.com
