Hi guys
Can you help me out a little. I just realized that my Charger motor sitting way more on right side from center of car. Is it normal and why is that? Is it only for steering gear? If I measured then on right side there is about 2,7" from subframe to motor side and on left side there is about 5" gap from left side on frame and motor side. So it makes about 3" motor sitting out from car center on right side.
Second question is about front motor plate. Do you guys leave original motor mounts and use them with motor plate or you take them away when installing front motor plate?
About steering rack. Do anyone use steering rack on he`s B-body? I really want to change old and heavy steering gear to rack. Main problem install...seems to me that oil pan causing some problems installing rack?
