Originally Posted By JimG
Originally Posted By AndyF
If it was my engine I'd probably run a Mopar .528 solid flat tappet since I know it works really well for that type of mild stroker engine
Andy, what sort of idle vacuum would you expect from the .528 cam in a 493? And would you install it straight up?
With the 509, it idles at a whopping 8 - 8.5 in hg. I'd like to see that improve just a bit.
Thanks!
Here is a cam article I wrote a few years back. Any of these cams would work fairly well in your engine. I think I have a few of these cams still sitting on the shelf. The Racer Brown cam for sure and maybe the Comp.
http://www.moparts.org/Tech/Archive/bb/Lobe.html
