well this is how I did mine (440). 1st make sure the timing and primary carb are set, then make sure your floats are set. Then adjust the rods so that at WOT the blades are all the way open. Then it is a matter of getting the correct springs. The springs are what open the outboards. My car liked the purples.
[IMG]http://i66.tinypic.com/pui5j.jpg[/IMG]
Coming soon!!!!
